Rear view cam comes on in Drive
Hot Pepper Red Zeppelin
the land south of the blackface tyrant
2019 Ranger XLT
This started on the weekend. In the manual it says the camera should only come on when shifter is in reverse and if it's coming on when not in reverse to have it checked out. One weird thing though is when it is on in drive there is a "cancel" button in the top left corner and if you hit it the camera will turn off.
FULLSCALE
Adam
Ontario, Canada
Does it stay on all the time, no matter what speed you’re going?
DeathRanger
Peyton
Kansas
2019 Ford Ranger Lariat Sport 4x4
IT
Have you updated your sync to the latest version?
Arizona
CEO of DeeZee
It goes off at 6 mph also just like it does normally.
Has sync been updated recently? Mine was current just a month or so ago.
If it's going off at 5-6 mph than that's normal. There's a setting you can turn off so it doesn't come on when you put it into drive. I turned mine on because I like this feature.
Arizona
CEO of DeeZee
So if you put your truck in D without first putting it in R and backing up your camera comes on? That's what mine is doing. Here is the section from the manual that indicates something is wrong.
No I don't think that's right. I thought you were going from R to D. There's a section in the settings where you can add a delay (5 sec) so your camera stays on in D but you have to have been in R first.
t4thfavor
Chance
There's a setting in mine that will allow the camera to stay on to +5 or +6mph no matter how long. There is a cancel button in this case. I think this is normal operation.
chasvs
Tampa
Where's that Setting located?
2019 Ranger XLT
So I played with this today and it is the rear camera delay that is causing it. I had turned that setting on just a couple weeks ago but I almost never start out going forward, I'm always backing up. Last weekend circumstances had me starting out going forward several times. Anyway, if you have the RCD setting on and shift into drive the camera image will come on and there is a cancel button in the upper left corner where the zoom controls are when in reverse, if you press the cancel button the image will go away, if you don't press the cancel button the image will go away at 6 mph.
FULLSCALE
Adam
Ontario, Canada
I have the camera delay setting on but mine doesn’t come on in D unless I shift into R first.
hughesjv
Aurora, CO
2019 Ford Ranger Lariat FX4
Late tot he game...I was about to post the section about Rear Camera Delay to see if that was what it was...I am glad you have it figured out!
drman2013
2019 Ford Ranger XLT
There is a option in the Display settings that will allow you to enable or disable the Delay on the rear camera. The delay is so you can see what you ran over when as you drive away! lol! The Manual is very helpful!
Maybe shifting to D just slow enough to trip the camera going past R?
