Light Bars??
  • Thread starter Deleted member 773
  • Start date
  • Watchers 38
James Caper
Calgary
2019 f150, 2019 Ranger
Its easy to mount one up there. I dont have ACC so no worry. You use the bolts that come with the light bar and for round punched backplate bar behind the grill to secure the light bar to the lower portion of the grill. No drilling or cutting required. Done this on last 3 F150's
Arizona
CEO of DeeZee
I have a 23" to install, and I have ACC
What are my options? Obviously in the bumper I'm affecting my radar unit. behind the grill I may lose some light from blockage. which i am ok with if its minimal.
Has anyone worked around the issue with success?
I want it inconspicuous and my options are limited.
whats behind the grill for mounting possibilities?
Check out the post below. He has his mounted behind the grille.
Light Bars??
James Caper
Calgary
Where did you get your Ford emblem overlay?
Nice Job
RangerRaptor
Denver
2019 Ford Ranger Lariat (previously 2012 Ford SVT Raptor)
scubalizard
Houston
2019 Ford Ranger XLT
Looks like i am going to relocate my license plate below the ACC and mount a lightbar just below the grill using the cutouts in the steel bumper. I have the sport grill, so unless i want to replace it or cut out a hole, think that this is my only option.
BcP28
Bennett
2021 Ford F150, 2015 Ford Edge Sport
I don't have ACC to worry about, but I used that location to bolt on a bar I made with some aluminum tabs and remnants of an old cross-bar. Worked pretty well with the light bar going below as well.
Hi Bennett,
A very nice install!
Deleted member 1634
Looks good! The pods remind me a lot of my setup. Luckily my truck is Saber, so we're still different enough to stay unique. haha
Dredgerie
Greg
Nevada
Magnetic Ranger Supercrew
Doors anyone have a 3D printer? Making side mirror caps with 2” or 3” mounts sounds pretty good... At least, I’d pay for them. Beats having dual ditch lights on each side to get around the ACC sensor.
FASRanger
Scott
Maryland
2019 Ford Ranger, 2014 Mustang GT/CS and a 1989 GT Mustang vert.
Aerospace Lab Technician
I am either relocating my ACC (which I've seen some pricey brackets made for) or most likely just going to remove it so my 20" Rough Country light bar will tuck nicely in that area..... I do about zero percent highway driving and never use cruise control so...?...?
