Easy wiring solutions for lights etc.
@Robby887
Diamond Sponsor
Robby Woolworth
Las Vegas
2019 Supercrew Fx4 xlt ford ranger
Fabricator/welder
ScubaSteve
Astoria, NY
2019 Ford Ranger STX, 2019 Jeep Wrangler JLU
Just want to say that I whole heartedly endorse the Trigger products. I have the Trigger 4 Plus installed in my 2019 Wrangler and it's probably my favorite add on. It was a super easy install, made wiring my a-pillar and ditch lights a breeze, and I haven't noticed any difference in reliability between the Trigger system and a wired light control panel.
BHunted
Sumner County, TN
2019 Ford Ranger Lariat, 2019 Ford Mustang
BHunted
Sumner County, TN
The new Trigger 6 shooter installed in my 2019 ford ranger. Easy set up and Bluetooth control from your phone. 10% discount for members.
http://triggercontroller.com/phone/index.html
Email [email protected]
Call or text 702-501-3139
www.fordrangerlifts.com
www.woolworthmotorsports.com
Got Trigger wired and tested. How the heck did you attach module by battery?
Trying to keep it tight and right is tuff. Tried big tie wraps. I can’t see any means you used to secure it.
Any help appreciated....
Not to speak for Robby but I have mine just sitting on top of the battery...it doesn't move at all:)
BHunted
Sumner County, TN
It’s not too high and hit the hood? How did you get it to stay secured?
It just touches the liner...as you can see, the RF antennas stay up...just where it sits, it doesn't move in any direction even after 10,000 miles and many many speed bumps...
BHunted
Sumner County, TN
Thanks again... I threw a tie wrap around it just in case.
Gino Munoz
Gino
Orange County
I just pick one up a noob question where did you run the yellow wire too.
i just realize that I got the Trigger 2100 controller 4-switch. It has a accessories wire which is yellow.
Ah right...the yellow is to be connected to an accessory power line (+), in my case, the marker lamp. That way, the power is only armed when you have the marker turned on and will not be accidentally powered up if there's radio interference...:)
Gino Munoz
Gino
Orange County
Thank you I get all wired up today.
Gino Munoz
Gino
Orange County
I disconnected the battery wired everything up and now the truck won’t power up. Any solutions
What?! Is the terminal tightened up correctly? I can't think of anything that would keep the truck from powering upo_O
