Deleted member 773
- Thread starter
- #1
No, in addition to - speeds the washing process up. Just use the "wash" foam to clean the vehicle, then with your mitt go over the applied foam. I also use it to apply an automotive degreaser like "clean slate" to my Ranger.does this eliminate the need for hand washing with a sponge
Like DIYAndy said, no, it doesn’t, but by removing 99 percent of the dirt and bugs on there with water alone, there’s significantly less scrubbing and potential for scratching. I’ve been using this soap, the high pH aids in de greasing, but it doesn’t seem to remove wax which is nice. It rinses particularly well too.Good Morning. Question: does this eliminate the need for hand washing with a sponge or whatever or is it just a high pressure rinse/soap application?
Thanks
I have one, I add a little bit of Dawn to the car soap to make it shaving cream consistency.A high pressure "foam cannon" will complete everything you need, for your pressure washer, to clean/wash/wax your Ranger
Just a note - adding Dawn to the wash will strip off wax - at least some of it. I never realized that until a couple years ago, and now only use car wash soap.[/QUOTE]I have one, I add a little bit of Dawn to the car soap to make it shaving cream consistency.
[/QUOTE]Just a note - adding Dawn to the wash will strip off wax - at least some of it. I never realized that until a couple years ago, and now only use car wash soap.
Which harbor freight unit do you have? I have the Portland 1750 psi, didn't realize it was proprietary connections until after I opened it. Got it cheap too.I have the Harbor Freight with the Wand for Foam Cannon connection from Amazon. Perfect to wash the truck. Foam, mitt cleanse with 2 bucket method and one separate bucket for the lower areas, tires and wheel wells .
Yes, you can still get the diff hose and fittings for it. That's the one I haveWhich harbor freight unit do you have? I have the Portland 1750 psi, didn't realize it was proprietary connections until after I opened it. Got it cheap too.
