Sandman Ranger Build!
Sandman Ranger
Sandman Ranger
Pete
Lead Process Engineer
Back for some install work from original purchase list.
Loaner vehicle for a few hours.
F150, all bed. Wider truck but most of the width is door thickness. Side impact rating must be good.
Item installed today was the Ford touch link LED lighting system. Will get some pics when sun goes down.
Light is more cool white in person.
Touch any light with two fingers and all come on. Touch again for off.
Julian
Julian
Connecticut
2019 Ranger Lariat Crew Cab; 2013 Edge Sport; 1965 Mustang GT Fastback; 1987 Mustang LX 5.0; 2012 Backdraft Cobra w/ supercharged Coyote
Sorry to fog owner!
My girls insisted I install their sticker on the Ranger. So, sorry to the dog owners. I am sure they are wonderful.
When young.
Jo (short for Josephine). My focused one.
Sorry all, but I must concur
Sandman Ranger
Sandman Ranger
Pete
Sandman Ranger
Sandman Ranger
Pete
Front License Plate Holder.
Had plans to remove the front plate holder and just leave the front clean, but I found a great looking “FX4 Off Road” plate. Metal plus acrylic design. Might not hold up more than a year but looks good for now.
This now clears the way to remove the rear quarter panels FX4 stickers and have clean sides or maybe matte black or matching magnetic FX4 letters. Removed the plate holder to see how it mounted. My Nephew did not have one on his truck and needed some info. The OE holder scratches the magnetic painted metal bumper so I added a layer of film to protect it from the plate.
Film added in this picture. Only under plate holder.
Sandman Ranger
Sandman Ranger
Pete
Sandman Ranger
Sandman Ranger
Pete
Added videos for Bed Link Ford option. Well made, good LED light and works well.
Sandman Ranger
Sandman Ranger
Pete
Bushwhacker Sill Guards
Installed the passenger side today.
Easy install and good fitment.
Hardest part is getting the red tape cover strip started. Have to use tweezers!!!!!!!!
Rear door should wrap under entire length of door like the front. But OK.
Seals all the way around the piece and covers entire underside.
DBaz
Dan
'19 Ford Ranger Lariat FX4
Great mod. Excellent protection for sills and if you run a step it keeps shoes from rubbing on the paint.
Once I did the first side, the second went a lot faster.
Snorebaby
Augusta, GA
@DBaz Since you have running boards...did you have to remove them to install the guard?
Sandman Ranger
Sandman Ranger
Pete
Driver side done.
Sandman Ranger
Sandman Ranger
Pete
I could be wrong but will answer for him.
If you have a clear shot down to the pinch weld then you might be able to install with steps in place. But it might be hard to slide them in place.
Best would be to remove the step. Brackets could maybe stay in place.
I am waiting for power steps so hope the Bushwhackers will not interfere. If the steps bolt to frame then I am OK but depends how close they fold to body. I hope they have an adjustable stop point.
But I wanted to install to prevent damage to underside. How some can run without mud flaps? I waited 2 weeks for mine and have a couple nicks.
DBaz
Dan
I installed the running boards after the guard, but I think there's enough room to do it the other way round.
Sandman Ranger
Sandman Ranger
Pete
Engine Cover. Foamy!
Had the dealer order the engine cover and bolts. Took only 3 days. Guess they have more inventory than an OE hitch which is still not in.
An odd cover. Made from dense foam. Don't hit it with anything. Feels like you could chunk it out.
I guess the foam helps absorb sound. Wish it was plastic and a little larger. The exposed bolts are also odd. Does it help? Yes, maybe. The start/stop is quieter. Will have to remove one time and test drive to see. Price info below and part numbers.
