SOLAREAGLE
- Thread starter
- #1
Bought this truck 26 days ago....Put in new plugs, spark plug wires and ignition coil. It did not run as I thought it should!! Off to 'you tube' I did go.There was throttle cable slack above the gas pedal! 1/2 inch or so...So, I followed his lead and put 5 zip ties between the bottom of the slack to the top of the throttle cable... And it did the trick.....P.S. CABLE DOES STRETCH AFTER 22 YEARS OF USE..................
