I can confirm this setting:Some killer info here, thanks to all. Happy with the changes!
Encountered one weird issue disabling the welcome screen:
Disable IPC Welcome Screen: 720-03-02 (2013+ MY) xxxX xxxx 4 (Disabled)
Note: No Blue Sky Background on IPC when getting into vehicle
It worked perfectly and the startup is way faster...but it only lasted until the next engine start/stop cycle. The "4" digit is still in the correct place, it just doesn't work anymore. Maybe someone else has been through this and has a solution?
One thing that does work is the setting for the panic button on the fob...to make it require a double press instead of single (to avoid accidental activation).
BCM 726-37-01
XXXX-XXX*-XXXX 1 double press to activate, 0 to disable
BCM
726-37-01 xxxx xxx2 xxxx Panic alarm on fob enabled
726-37-01 xxxx xxx1 xxxx Panic alarm on fob requires 2 presses
726-37-01 xxxx xxx0 xxxx Panic alarm on fob disabled
I have never used this on purpose but I have accidentally triggered it a couple of times by accident (sometimes with the fob in my pocket). This will hopefully reduce or eliminate those "false positive" emergencies.
