adding an e-locker after purchasing
LISANDRO
Lisandro
california
2019 ford ranger xlt
Hello just bought my ranger from the lot. is there any way to add an e-locker to it or what is recommended.
chasvs
Tampa
Probably a good question to have asked before you bought it! I highly doubt you can add afterwards.
Rinn69
N. Central Iowa
Retired USAF MSgt
From what others have posted previously, the e-locker is a different unit installed at the factory. In other words, they have 2 rear ends to install-- one with an e-locker and one without. So, it's not possible to install one unless you swap the entire rear end out with an e-locker unit. Maybe ARB will come out with an air-locker kit.....
LISANDRO
LISANDRO
Lisandro
california
Thank you for the feedback sounds like i surely messed up not asking before purchasing as it is my first truck and dont know that much
Rviator
FLA
retired aerospace engineer
You'd probably be better off finding out what rear axle is used, ie Dana, Ford, and then installing the appropriate p/n True Trac or Trac Lok.
t4thfavor
Chance
Dana M220 is the rear I believe. Should be lots of lockers eventually as it's similar to what Jeep is using. The issue is I have read that the gears are welded to the carrier, so a carrier change might require gears to be changed too.
That said, the brake actuated LSD is actually ridiculously good for a software solution so you "probably" don't really need the E-Locker. All in all you should have gotten an FX4 :)
You could also call Eaton, I believe they are the OEM supplier for the locker, they may have one you could buy, and wire a separate switch for.
Sorry about your luck.
XRANGER2019
STEVE
OHIO
2019 FORD RANGER XLT SPORT 4X4
HYDRAULIC TECH
YES EATON MAKES A TRUE TRAC AND AN E LOCKER THAT FITS A BRONCO RANGER OPEN 32 SPLINE AXLE
Friday yet?
Lariat Tremor, Focus ST
Thread is 3 1/2 years old. Just fyi.
Highlander
Frank
Nova Scotia, Canada
Private
jleds
Jay
Honolulu
2019 Ford Ranger XLT
THIS FITS A RANGER WITH A NON-LOCKING AXLE M220
Hey man question for ya. How do I verify I have the M220 32 spline? I'm interested in going the Trutrac route but installers are hesitant because they can confirm the fitment. Appreciate the input!
