Key Chime Delete
shirleyb
Spokane Washington
2019 Ranger, Shelby GT-500, Edge
I find the key chime loud and annoying, so I did the fix.
Open fuse box cover. It snaps open from the top. I greased the snaps when I finished the delete fix.
Remove the 3 screws that hold the cover below the ignition switch (7MM)
On the bottom of the ignition switch there is a micro switch plug with 5 wires, and one socket is empty.
You will cut the blue wire with a red stripe. It will be next to a yellow wire which is power to the switch.
I cut it about 2 inches back from the plug, in case it had to be spliced.
I wanted to remove the socket, but it is so small I could not get it to release from the connector.
I have a 2019 Ranger XLT, so your plug must match mine. I hate cutting any wires, but this solution worked for me. Key chime gone, all other chimes work.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
This can be done through Forscan without any disassembly or cutting along with almost every chime that's annoying.
