Jason L
- First Name
- Jason
- Joined
- Jan 28, 2019
- Threads
- 6
- Messages
- 111
- Reaction score
- 71
- Location
- Mount Pleasant, SC
- Vehicle(s)
- 2019 Ranger XLT 302A
That part looks correct for the bracket, but says Class I in the description. It can't be class I as the bumper alone tows more than that, and it has a 2" receiver.Did you happen to figure anything else out here? My truck is coming without tow package and I’m planning on adding it. Bolting on the hitch should be easy, but I can’t tell if I will need to add a 7pin connector or do any orther wiring work.
I did confirm it does not have the wire harness or the 7 pin connector. I know the bumper mount connector is on back order. I have not yet found the right harness.
My dealer said they would call as soon as the complete package shows up as in stock.
Looking at bottom of truck, this looks like a fairly easy upgrade. You do need to pull the entire bumper, but its 4 screws and one wire harness connector. Swap out the light duty plate and 4 pin harness for the heavy duty plate and harness, 6 screws remounts.
I think figuring out what to order is proving to be the difficult part, but should clear up as soon as Ford puts the entire package online.
