Ann M Scheib
After 300 miles I am getting 19.1 mpg.
I'm not sure, but...when the EPA calculates MPG, aren't there specific guidelines that must be followed? I would hope there are, so everyone tests under the same rules...highway speed specifically.We will all have to find the trucks sweet spot. My 2005 Ranger 3.0L got 24 mpg at 65 mph and 19 at 70. Just my take on things. Cruise, hole shots and driving style mean a lot. Go as fast as your wallet can afford.
Is anyone wondering what the 2.7 Ecoboost V6 mpg would be in the new Ranger?
F-150 Supercab 4WD with 2.7L EB:
325 HP, 400 lb-ft torque
79.9 in width, 76.9 in height --> 42.7 sq ft frontal area
4805 lb curb weight
Mpg: 19 city, 24 hwy, 22 combined
Ranger Supercab 4WD with 2.3L EB:
270 HP, 310 lb-ft torque
73.3 in width, 71.5 in height --> 36.4 sq ft frontal area
4232 lb curb weight
Mpg: 20 city, 24 hwy, 22 combined
The 2.7L in the F-150 is rated equal hwy/combined mpg and 1 less city mpg, even though it has 17% more frontal area, weighs 14% more, yet delivers 20% more HP and 29% more torque than the 2.3L in the Ranger.
I've been trying to find that page on fuelly, can you point me in the right direction? It'll be interesting to watch as there becomes more than 5 trucks being monitored (3 of which are diesel).This is what Fuelly has for the 2019 Ranger. Looks like we have five people tracking on it so far.
In general, the more efficient the engine, the bigger the hit when idling. My old diesel car can top 50MPG on the highway, but that plummets when standing still because the amount of fuel used at idle changes much less from car to car than the amount of fuel used when cruising; the average of the idle consumption and the highway consumption is a much bigger delta at 50MPG than it is at (say) 8MPG.I really think this engine uses an above normal amount of fuel when idling.
Just doing spot checks, but even in this thread it seems the discrepancy is between people in colder climates + stop and go traffic, vs those in warm climates + highway driving.
I really think this engine uses an above normal amount of fuel when idling. Thankfully this truck has auto start/stop but given the time of the year it is most of us are using our heaters and defroster which will disable the start/stop.
Can you guys with really high or really low MPG give us an idea of what the normal temp is when you're driving and if your start stop is active, as in its is on AND actually turning on and off?
I've gotten over 26 MPG and I've had periods where my average MPG is under 18. I've noticed I get the advertised MPG when doing normal driving with a mix of highway and city, but only when its warm enough for the auto start/stop to work correctly, but if its cold and I'm using my heater and defroster and my start/stop is not activating then my MPG plummets. Remote start also destroys my MPG if I use it daily, even when its only on for 2-3 minutes before I take off.
I suspect all our MPG ratings will magically increase come Spring
The city test schedule that the EPA requires for MPG testing specifies a lab setting between 70-80 degrees, and over the period of the test there are over 20 stops and the engine is idling 20% of the time. In those lab conditions it most likely means the engine is actually off for 1/5th of the test. So if you're in a cold area no way your MPG will match the EPA tests, just based on the fact your engine is on much longer than it was in the EPA test.
Just went though this in a video I posted recently. There's about 10 conditions that must be met for auto start stop to work. Battery must be fully charged, cabin must be warmed to desired temp, electronics can't be pulling too many watts, front defroster must be off, wheels cant be turned too much, etc. You can see it in this video if you pause at 13:26 - videoI have a thread somewhere on here where I and others discuss my Auto Start/Stop. It seems to be active above 25F or so. In addition to the other known reasons for it to shut off, that seems to be a definite factor. My average MPG on the dash is between 21.5 and 22.5. It's been stupid weather her in Michigan though, so it's fallen towards the lower end of that with 60mph head winds, single digit temps, and snow every other day.
FX4 Truck?1400 miles, 28.5 mpg’s this morning with mixed driving conditions!
4x4?FX4 Truck?
Yes4x4?
