iPhone Bluetooth Capabilities
Pat McGrath
Pat
Philadelphia PA
2019 Ranger 4X4 XLT Supercrew
I have a question regarding my Bluetooth capabilities. I ordered an XLT with the 502 A package, will my Iphone GPS sync with the vehicle screen?
rangerdanger
SF Bay Area
I assume you’re talking about Apple CarPlay or Android Auto, it only connects to your phone with a cable, not wirelessly with Bluetooth.
You can use Bluetooth to stream music, take phone calls, etc... but to mirror your iPhone screen you’ll need to use a cable with Apple CarPlay.
Pinecrestjim
Pinecrest, FL
You can connect your iPhone to Sync and use ApplePlay to show your Apple navigation map on the Sync screen.
Pat McGrath
Pat McGrath
Pat
Philadelphia PA
Would that be the same cord I use to charge the phone?
Rinn69
N. Central Iowa
Retired USAF MSgt
Some folks have issues if they use a non-Apple cord, so use the cord that came with your phone :thumbsup:
Pat McGrath
Pat McGrath
Pat
Philadelphia PA
Can I find carplay in the app store or somewhere else?
Pinecrestjim
Pinecrest, FL
I can't say for certain but the latest version of SYNC should have the application already installed. It would have to be enabled in Settings if I recall correctly from when I upgraded the SYNC 3 in the Escape.
MT19RANGER
JERRY
SIDNEY, MT
Pat, have you downloaded the owner's manual? There's lots of information in there and I've read over it several times when having questions. @rangerdanger I can't find the link, where are they again for download?
rangerdanger
SF Bay Area
rangerdanger
SF Bay Area
CarPlay is integrated into the Sync 3 system. As long as you have a iPhone 5 or greater it should work.
David Ambrose
Palmdale, CA
2019 Ford Ranger Lariat
Is there a way to switch between Apple CarPlay the Sync 3 without unplugging the cord?
rangerdanger
SF Bay Area
CarPlay is an app built into Sync 3. You can charge your phone and not use it.
Pinecrestjim
Pinecrest, FL
Edited to correct the original post: Yes. If you are at the main Apple CarPlay screen that shows various apps, just select the Ford Sync icon. If you are in a CarPlay app, press the white circle in the bottom left of your screen to take you to the main CarPlay menu screen.
