FoD
What you don't see is the strap ties outside picture left where the tow partner just unhooked?Hope that was in 4H. lol
Hi Steve...the four Rigid lights in the grill are connected to one of the Six Shooter...there's six outlet/switches goes without saying...Love the setup!
I tried sifting through the whole thread but may have missed it. Hope im not re asking a question. For the rigid lights in your grill. Are they on a seperate switch or do they turn on with your fog lights, high beams? Or are they wired in into your marker lights? I like the idea of the pods over the light bar in the grill. I know the raptor grill lights I ordered tie into the side marker light. Not sure if the rigid pods are similar and will cause an issue hooking up.
I may be referring to the wrong lights you're asking so which one exactly are you pointing to? ?
That is a very impressive set up you have there Sid5x8 awning mounted...wanted a brand name but none of them makes one in this dimension...this Amazon deal is better than I thought and saved a few bucks...
Thanks Greg! I'm going broke impressing ya'llThat is a very impressive set up you have there Sid
You are more than welcome If I seen this in my rear view mirror I would think aliens are after meThanks Greg!
haha good point. The lower 4 lights in the center. I was examining my bumper. Do they just mount into those little snaps underneath? I havent seen much info on the rigids elsewhere on them. Do they come with come with the mounting bracket and wiring kit like the baja brand does? Im new to the mod game so bare with me. My ranger is the first vehicle I have that I can dump money into upgrades and not repairs lol.Hi Steve...the four Rigid lights in the grill are connected to one of the Six Shooter...there's six outlet/switches goes without saying...
There are 5 total snaps...use the two outer ones...pull them out and bolt through to mount to bumper with brackets that already come with Rigid...can't get any easier than thathaha good point. The lower 4 lights in the center. I was examining my bumper. Do they just mount into those little snaps underneath? I havent seen much info on the rigids elsewhere on them. Do they come with come with the mounting bracket and wiring kit like the baja brand does? Im new to the mod game so bare with me. My ranger is the first vehicle I have that I can dump money into upgrades and not repairs lol.
Sid, those racks adjustable side to side?Another step closer...got my "Last Line of Defense" style Front Runner racks mounted to the Diamondback...without the RTT loaded, both hatch open normally
What do you mean John? The load bars can slide to one side or another but I like them centered...Sid, those racks adjustable side to side?
I agree. I asked because was wondering in case the bar had to be fixed only in one position and the posts had to be a specific spot on the bar. Not knowing exactly the width on the tracks I showed you for different brands. Some companies don't specify which trucks like one says mid-size pickups or full size pickups. Follow? So my concern should be as long as they are not wider than the body and can slide to 'be centered' as you mention.What do you mean John? The load bars can slide to one side or another but I like them centered...
The Front Runner bars have a single slot the whole length of the span (top and bottom) with a couple of enlarged slot to allow the bolt head to drop in and slide to any position you prefer...I agree. I asked because was wondering in case the bar had to be fixed only in one position and the posts had to be a specific spot on the bar. Not knowing exactly the width on the tracks I showed you for different brands. Some companies don't specify which trucks like one says mid-size pickups or full size pickups. Follow? So my concern should be as long as they are not wider than the body and can slide to 'be centered' as you mention.
Just got to figure what brands are compatible with tracks or have adapters....
