Ford Performance Ranger Raptor rims
Denver133
Denver133
Denver, CO
2019 Ranger on order
My dealer is still waiting on pricing and info on these rims, but we do know part numbers.
M-1007K-RGR1785OR
I did a very fast cut and paste to see what they would look like on my build. I think with the lift and fender flares, they will work for what I was going for.
Desert_5G
Eric
Arizona
Tacoma
M-1007K-RGR1785OR
I seen somewhere they will go for $1k a set.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
Those are what's going on mine as soon as they're available. I already have the tires to go on em!
Denver133
Denver133
Denver133
Denver, CO
285/70/17 BFG KO2's? Thats what I was planning but don't think they will fit without a little lift.
Mires
Missouri
Nissan Xterra
I'm going with these TRD Pro wheels. They look similar to the Raptor wheels but better imo. I'll of course change the center caps though.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
Denver133
Denver133
Denver133
Denver, CO
mURmECH
HI
2018 Raptor, 2019 Ranger
Josh, when you get your Ranger, are you planning on putting the new tires in soon after? I want to get that same size but don't know about the rim and if it needs to be lifted a couple of inches. If so, I'd rather get the lift first otherwise I'll go with the tires.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
Yep, it'll most likely be the first thing I do to the truck. I'll be the guinea pig for you guys! Just hoping the wheels become available soon.
Denver133
Denver133
Denver133
Denver, CO
Looking at tire size comparisons, we are talking a two inch difference in total diameter from either the 17 or 18 OEM options to the 285/70/17. It will be close without a lift.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
yep, the stock Hankook Dynapro ATM 265/65R17 have a 30.6" overall diameter, and the BFG KO2 285/70R17 is 32.8".
2.2" of diameter difference which of course means 1.1" of additional clearance is needed. I think they MIGHT fit, but it'll be damn close. I plan on adding the 3" Fox leveling kit anyway once available.
Denver133
Denver133
Denver133
Denver, CO
Our trucks will be very, very similar. Love it!
Stic-o
Lake View Terrace, CA
You gotta look at width to, because that's where you will run into problems rubbing at full lock. I was looking at the bfg in a
265/70/17 which is a 31.7" and 10.7" wide
or a
255/75/17 which is 32.1 and 10” wide.
Vs.
285/70/17 which is 32.8 and 11.5 wide
j0shm1lls
Josh
SoCal, USA
www.youtube.com
or a
Vs.
Good point! The stock Hankook Dynapro ATM 265/65R17 have a section width of 10.7", BFG KO2 285/70R17 is indeed 11.5". So I'm looking at 1.1" bigger front and back and 0.4" deeper. Its going to be REAL close!
