I am considering buying Apex Ultra Light 215BRK. The travel trailer weight is 4363 lb the length is 25' 4" . If I understand correctly the truck gross weight is 12,500 lbs. the truck+Cargo+people+trailer has to be under 12,500. Like here your input. thanks
Share
With the chart above.....you have 3137 lbs to go to max out.Maximum Conventional Towing Capabilities
SuperCab
Drive Type
4x2 (Pick Up Box Delete)
4x2
4x4
Engine with Automatic Transmission
2.3L EcoBoost® I-4
2.3L EcoBoost® I-4
2.3L EcoBoost® I-4
Wheelbase
126.8 in.
126.8 in.
126.8 in.
Axle Ratio
3.73
3.73
3.73
GCWR
12,500 lbs.
12,150 lbs.
12,400 lbs.
Maximum Conventional Towing Capabilities 7,500 lbs.
7,500 lbs.
7,500 lbs.
SuperCrew®
Drive Type 4x2
4x4
2.3L EcoBoost® I-4
2.3L EcoBoost® I-4
Wheelbase
126.8 in.
126.8 in.
Axle Ratio
3.73
3.73
GCWR
12,250 lbs.
12,500 lbs.
7,500 lbs.
I am towing a Sportsmen 271 BHLE, it is listed as 31'3" @ 5,290 dry, so maybe 5,800lbs loaded, propane, bikes etc ( I don't fill my water until I get there). I have a Redarc brake controller and I use the E2 weight distribution with friction sway control. Tows like a champ. I am honestly blown away by how easily the truck pulls it and how steady it is. Watch some videos about how to set up your weight distribution correctly. It requires measurements of truck and trailer alone, hooked up with and without distribution. Don't assume the travel trailer dealer is setting it up properly. When I bought my trailer I still had my F-150 and that thing swayed terrible above 50 mph until I made adjustments. The Ranger feels just as stable as my F-150 did with both set up correctly. The 2.3 doesn't pull as effortlessly as the 2.7, but it really impresses me non the less.I am considering buying Apex Ultra Light 215BRK. The travel trailer weight is 4363 lb the length is 25' 4" . If I understand correctly the truck gross weight is 12,500 lbs. the truck+Cargo+people+trailer has to be under 12,500. Like here your input. thanks
Share
Hi Bobby,I am considering buying Apex Ultra Light 215BRK. The travel trailer weight is 4363 lb the length is 25' 4" . If I understand correctly the truck gross weight is 12,500 lbs. the truck+Cargo+people+trailer has to be under 12,500. Like here your input. thanks
Share
I would use an equalizer hitch.With the chart above.....you have 3137 lbs to go to max out.
I've towed a 5500 travel trailer over 10000 miles without any incidentsI am considering buying Apex Ultra Light 215BRK. The travel trailer weight is 4363 lb the length is 25' 4" . If I understand correctly the truck gross weight is 12,500 lbs. the truck+Cargo+people+trailer has to be under 12,500. Like here your input. thanks
Share
Averaged 8, AZ to Wy. 13 WY to Oh. 10.8 Overall. At an average of 70 mph. (2019 Lariat, Rouse cold air intake, Ford Performance (Borla) exhaust.You guys towing those huge trailers, what kind of mpg are you getting?
Thats pretty good mileage. Better than i get with my 2016 king ranch with ecoboost. Havent towed with my rnager yet.Averaged 8, AZ to Wy. 13 WY to Oh. 10.8 Overall. At an average of 70 mph. (2019 Lariat, Rouse cold air intake, Ford Performance (Borla) exhaust.
