RCMUSTANG's Magnetic FX4
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
I've only found one quirk thus far - I seem to have been "converted" to a non US spec - Radio stations have two digits after the decimal and the speed limit signs display a circle with a red border (which is a European standard I think). Anyway, I recall hearing that if you enable navigation in motion it will display radio stations with 2 digits. I'm thinking this value might have done it:
7D-02-01 5753 0106 C04B
I think the 5753 should be 5553 for US vehicles. I will try that change tonight to see what happens.
The signs don't work for the US. I have it enabled and the spot is there but it's always blank.
With the 3.4 upgrade? Mine worked in 3.3, and I am seeing signs, they just look different now.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Yeah, I tried it with an older version on the Fusion and nothing ever showed up nor with the 19274 in the Ranger. I enabled it to test on the Ranger through Forscan easy mode though.
Trey1940
Trey
Martha's Vineyard, MA
2016 Fiesta ST, 2019 Ranger Lariat FX4 Sport
SUCCESS!! I'm not quite sure what the magic value(s) were (I was only trying to change exactly what I needed to) - I ended up changing 4 values to match the file that was attached here and after a couple attempts and power cycles, my climate menu returned.
These are the values I changed:
7D-01-01 AA2A 0403 03B7 - Note: I know the 3 in 03B7 turns on the heated seat icon on the home page
7D-01-02 022A 0204 8894
7D-02-01 5753 0106 C04B - the last quartet I had to do a couple of times - it kept changing to C04F after I wrote the data - it finally stuck after a couple attempts
7D-04-01 0000 3300 0D1C
Can confirm, experienced the same loss of the climate button and this fixed it!
Also did 7D-02-01 5553 xxxx xxxx instead of 5753 xxxx xxxx and it retains the US style radio and signage.
Thanks for confirming - I will make this change tonight.
Confirmed - I had to write all the values in order for it to take, but the only change was 5553 from 5753. I now have the "US" radio format and US format speed signs again. I did find out this is definitely the "navigation in motion" change - when it was swapped I was able to search for a navigation destination while moving.
Jorge
Jorge
Ford Ranger 2019 XLT
Puerto Rico
Auto up/down window module adds auto up and down on all windows now plus open, close and vent with remote control on key fob. If you want to be able to leave the windows down when you lock the truck you'll have to leave the wires disconnected and not have the remote features.
If anyone is interested I can start a thread for this as well.
I'm interested
DevilDoc
Nick
TEXAS
2019 Ford Ranger XLT 2.3L 4x4 sport
US GOVT
I'm also interested in the auto window mod.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Not doing the window modules anymore. You can go to the group buy thread for details.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
I have to say that 19274 is a little more buggy with android auto. I might switch back to 19101.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
A.R.E. CX Evolve. Finally showed up but at the same time a month early.
Jake596
Jake
Nevada
2019 Ranger XLT/2013 F-150/1976 F250
That topper is sweet, what make and model ?
2020FX4
El Jefe
Los Angeles
2020 FX4 Ranger
That looks great! I have never had a topper on any of my trucks, but It might possibly happen with my ranger.... Doing research and deciding what will be best for my camping set up.
Where did you get yours installed and do you mind If I ask how much?
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Your authorized dealer will install. Got mine at Sno Valley in El Monte. Cheapest I could find in my area. Ask for Stephanie.
